11-12-2021 01:54 AM - last edited 3 weeks ago by ROGBot
11-25-2021 12:17 AM
kaybee123 wrote:
It worked! Switching the ram from A1/B1 to the A2/B2 channel fixed everything.
In A1/B1, I couldn't boot past 4400mhz (and even then, it crashed so I was running it at 4000mhz).
When in A2/B2, I was able to boot at 4800mhz with XMP2. From there, I figured I try 5200mhz and that worked too! So today I just went from 4000mhz -> 5200mhz by switching the slots.
11-25-2021 02:42 PM
11-25-2021 03:30 PM
11-25-2021 06:44 PM
Silent Scone@ROG wrote:
Lesson here, read the manual if unsure 😉
01-18-2022 06:43 AM
01-20-2022 02:31 AM
02-28-2022 04:54 AM
02-28-2022 05:03 AM
02-28-2022 08:54 AM
Braegnok wrote:
If you need 64GB system memory, I recommend going with 2x32GB vs 4x16GB.
Check your motherboard GVL for 2x32GB compatibility, the Dell 4800MHz 2x32GB sticks are listed in my GVL: https://www.dell.com/en-us/work/shop/dell-memory-upgrade-32gb-2rx8-ddr5-udimm-4800mhz/apd/ab883075/m...
The Dell 2x32GB sticks will run fine in XMP 4800, or manual settings up to 6000MHz on my board.
Also the Corsair 2x32GB 5200MHz kit works on my board in XMP 5200, or manual settings up to 5600MHz: https://www.corsair.com/us/en/Categories/Products/Memory/DOMINATOR-PLATINUM-RGB-DDR5-Memory---Black/...
My advice would be the Dell 2x32GB modules, and run in enhanced mode @ 4800MHz CL32, CR1, 1.10V and you will be fine.
You need a CPU with a vary strong IMC to run 2x32GB above 5200MHz CL40, CR2 up to 6000MHz,.. and performance is not much better than 4800MHz CL32, CR1, 1.10V.
Good luck, YMMV depending on your CPU IMC.
03-01-2022 04:43 AM
birdjungle wrote:
If that is your system you are far ahead of me. I can't spend that kind of money anymore. Wife would kill me. I have a 12700K with a Samsung 980 pro and no discrete graphics yet. I'm looking for a 3080 but I'm just not paying those prices so until they come down to more reasonable prices I'll do without. I'm not gaming so the need isn't there.
Any reason why I shouldn't go with 4x16s? I can't drop over a grand on memory. These 2 kits cost me about $600 and honestly, I'm not sure I want to tempt fate and mess around with the MB again. Originally I was only gonna 2 32GB but I just don't feel like returning the memory. Already had to send the bad board back.
