02-23-2024 02:26 AM
I have Asus Maximum Z790 Hero motherboard.
Are the following settings in the BIOS safe for daily use with i9-13900KS CPU?
-CPU Load-line Calibration [Level 6]
-SVID Behavior [Best-Case Scenario]
02-23-2024 02:30 AM
Hi, it is safe, yes.
Whether it's necessary depends on what your end goal is. A higher voltage is always preferable over a higher LLC.
02-23-2024 05:10 AM
My goal is to reduce the processor heating.
I have better CPU temps with LLC 6 and SVID Best-Case... than with LLC 3 and SVID Auto or Trained.
However, if I set the SVID Behavior option to [Best-Case Scenario] and LLC Auto or LLC 3, LLC 4, or LLC 5, WHEA errors will occur in CPU-intensive tasks.
