Asus Z790 Maximus Hero - 6400mhz max speed XMP now ?
PYRRMD
Hello guys ,
I have a 6600mhz G.skill and wanted to upgrade to 7600mhz as i saw like a month ago on : https://rog.asus.com/fr/motherboards/rog-maximus/rog-maximus-z790-hero-model/helpdesk_qvl_memory/
but now , max speed on the list show , 6400mhz , is that normal ?
I swear i have seen 7600 or even 7800mhz but not sure  ?
What's your max XMP speed at the moment ?
I have a Golden chip 13600kf and IMC is pretty good , OC my 6600mhz to 7600mhz so far
1 ACCEPTED SOLUTION
Accepted Solutions
Silent_Scone
Super Moderator
Hi @PYRRMD ,
What is your CPU? The 12th-generation QVL indeed only goes up to 6400MT. The 14th gen maximum validation is 7800MT.
Silent_Scone
Super Moderator
Hi @PYRRMD ,
Am i stupid ?
- yes
did you helped me ?
- Yes
Can you Delete this post ?
- Yes
thanks again
