02-18-2021
03:28 AM
- last edited on
03-05-2024
01:49 AM
by
ROGBot
02-18-2021 08:04 AM
02-18-2021 08:23 AM
02-20-2021 05:25 AM
02-20-2021 12:43 PM
pmlfrew wrote:
I updated my drivers following this post : https://rog.asus.com/forum/showthread.php?118522-DRIVERS-Realtek-Audio-(MB-Intel-Z590-amp-AMD-TRX40) and thought the issue was solved but the problem still happens all be it with a longer frequency of occurrence. I did not install the realtek control panel again or any of the Sonic software as it mentions in the post.
I never had any problems with my previous motherboard, the amp and the cable. Hopefully I can find a coax to phono cable and I will try that to see if it suffers the same issue.
Hopefully it is a driver issue and will be fixed
02-21-2021 02:40 AM
Zardoc wrote:
Hi pmlfrew, I don't know what you mean by updated drivers. These are the only drivers available for the new USB 4080 codec ...
02-21-2021 12:32 PM
MoKiChU wrote:
This is wrong, the drivers package from your motherboard support page are the 6.3.9600.2276 WHQL drivers package version while the drivers package I offer from my thread are the 6.3.9600.2277 WHQL drivers package version.
02-20-2021 05:45 AM
02-21-2021 01:25 PM
02-22-2021 02:07 AM
