rog strix z590-a audio driver problem (6.3.9600.2393)
pascal_c
Since the last drivers version (6.3.9600.2393), installed from Armoury Create , Sonic Studio 3 not working anymore.
The error message is in french "Votre system n'est pas compatible, ou le pilote audio n'est pas correctement installé" - TIMEOUT
Your system is not compatible, or the audio driver is not installed correctly - TIMEOUT
How can i resolve this problem ?
MoKiChU
Level 40
You have an ASUS ROG SS3|DTS Sound Unbound motherboard with ALC40xx codec, so :
You need Realtek USB Audio Drivers (UAD - ASUS ROG SS3-DTS) from the first post of this thread : [DRIVERS] Realtek USB Audio (AMD 5xx/6xx/8xx & Intel 5xx/6xx/7xx/8xx).
To fix this TIMEOUT issue from SS3 app, follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
Note : I am French like you, don't hesitate to PM me if necessary.
