Problem when I power-up my pc - motherboard Asus ROG MAXIMUS XIII Hero
74lobster
Hi to everyone.
I own a motherboard Asus ROG MAXIMUS XIII Hero.
Sometimes when I want to access the PC, istead of the normal bood the PC shows thip page:
94885
I have not found a way to correct this issue...
I hope someones will give me the right solution.
Thanks.
74lobster
Nate152
Hi 74lobster
This could be a sign of a failing drive or corrupted windows.
1) Run CHKDSK on your drive.
2) Open command prompt as an administrator, type in sfc /scannow and hit enter, if any errors are found it should repair them.
3) Or, since it's saying a critical system driver is missing or contains errors, reinstall windows if your drive checks out.
Saltgrass
Level 14
74lobster wrote:
Hi to everyone.
Sometimes when I want to access the PC, instead of the normal boot the PC shows this page:
I hope someone will give me the right solution.
Thanks.
I was wondering what type of configuration you are running to need a Raid driver like that? I show that driver available in the Driver store, but it isn't needed for the basic motherboard operation.
Maximus Z890 Hero,
Intel Core Ultra 9 285K
