LightningService constantly using between 1-5% CPU?
Nitrius
The LightningService, which seems to be Connected to Aura Sync/RGB, allways use between 1-5%, is this normal behavior? I can stop the service, but then my RGB seems to freeze, not the biggest deal, but is there a way of either getting this process to clam down or get RGB without it installed?
This is on a Z590-F with Intel I7 11700k, Gskill 32GB Neo, and a Strix Rog RTX 2070.
PerpetualCycle
Unfortunately normal if you use anything but static color.
ROG Hero XIII | 10900k @5.2 GHz | g.skill 2x32GB 4200 CL18 | ROG Strix 2070S | EK Nucleus 360 Dark | 6TB SSD/nvme, 16TB external HDD | 2x 1440p | Vanatoo speakers with Klipsch sub | Fractal Meshify 2 case
