Z790 D ark Hero CPU Fan Speed Dection Error, New Build, Windows INstalled
tmyc
Asus screen 2024-2.jpgAsus screen 2024-1.jpgNew Build. I was able to install new Windows. It just won't boot up into windows to finish up.
  I'm gettin "CPU FAN Speed detection Error"!  I can't by this. I have the Corsair qfan setup. Can someone help me?  Its CHristmas night in Hawaii, and I'll probably have to call Asus tomorrow.
11 REPLIES 11
tmyc
Ok... Only 2 Sticks now and it was able to start windows. Had to add the drivers for LAN and Wifi and can now connect to internet.  Thanks.
Cool. Yes, the two kits are matched in as far as they're the same, but combining kits isn't supported. You can read more about the challenges of combining memory kits here.
