Z390i Only 1 DIMM recognized ... will *not* boot with second DIMM installed
dennislarock
Problem: Board Z390i - Only 1 DIMM recognized ... will *not* boot with second DIMM installed
CPU: i5 9600k
RAM: RAM G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 4000 (PC4 32000) Model F4-4000C19D-16GTZ
Each works in DIMM slot 1, but, machine will *not* boot with second DIMM installed in slot 2.
Updated the BIOS... to 2417 (6/3/2019) ...still not working.
Not running terribly with one DIMM... went ahead with stock (out-of-the-box) OC anyway ...5gHz on cpu & 4300mHz on ram. *Totally Stable* during 4 hr. bench test.
Would be nice to have 16GB of ram though... any thoughts???
thanks in advance
dennis
NemesisChild
Level 12
Try loosening the cold plate on your CPU cooler. It can cause memory issues as you describe if it's too tight.
Good luck!
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
