I have a Z390-F Gaming motherboard and my temperature sensor input has started reading ~100 C (its in air)
Does anyone else have the same sensor and a multi meter and would you mind telling me what the "ambient" resistance reading is on it please? 😉
That way i can compare it with mine and see if the sensor is suspect or if the problem is something else.
Thanks in advance
Peter
