Z390-E sata mode selection must be changed to raid mode to avoid unknown issues
Kommune
I own a Z390-E installed another CPU and got the following error after first boot:
"sata mode selection must be changed to raid mode to avoid unknown issues"
After pressing F1 and changing different values for testing now reboot is possible.
When i only do Ctrl + Alt + Del booting into Windows is possible and System is running stable.
The error is most known with a low energy CR2032 Bios battery, but my battery is powered well.
I hope that someone has a solution for me.
achugh
Level 14
What CPU were you using that was working? What is the new CPU that you installed? Are you using the latest BIOS version for your board?
Disclaimer: I am not an ASUS support person so my information may be incomplete. Always follow official documentation and material provided by ASUS representatives.
INTEL i9-14900K / CORSAIR VENGEANCE RGB 192GB (4x48GB) 5200 CAS38 / ROG Z790 DARK HERO / ROG TUF GAMING RTX 4090 OC / ProArt PA-602 Case / SEASONIC PRIME TX-1300 ATX 3.0 / CORSAIR MP700 PRO 2TB PCIe Gen5 / CRUCIAL T500 2TB PCIe Gen4 / EIZO CG2700X
Kommune
I have installed before I5-9500 and now it is a CC150.
Bios is latest version 2101
A problem might be outdated Microcode Version 0xfa.
0x100 should be the latest Version.
Hi @Kommune I believe you are using a CPU meant for Datacenters. Datacenters only run on RAIDs hence your CC150 not supporting SATA mode makes sense to me because a Datacenter CPU will have no need to use consumer grade technologies like E-SATA/SATA. These specialized CPUs are optimized and tested for enterprise technologies.
This is a guess on my part. I do not have any technical material to support this information.
