04-17-2018
09:16 AM
- last edited on
03-06-2024
08:56 PM
by
ROGBot
04-17-2018 01:27 PM
Menthol wrote:
Unless you have an LN2 switch on the motherboard that has been switched to the on position, return to retailer or RMA
04-18-2018 06:49 AM
04-17-2018 12:39 PM
04-17-2018 01:29 PM
ssuteck wrote:
Go in your bios at startup and check your bios overclock multiplyer setting of the cpu. Make sure it isn't set to 8. It should be in auto just to check. The only other thing I can think of is to make sure your CPU is seated correctly.
04-18-2018 02:54 AM
04-18-2018 03:16 AM
04-18-2018 11:48 AM
