X99 Strix + Samsung 960 pro SSD disappears on reboot
java2
I just installed Samsung 960 pro (M2 NVME) SSD on my X99 Strix board with Windows 10 installed.
The SSD is booted normally for initial power on. However, the SSD will be disappeared no matter BIOS or Windows reboot and the PC will go into BIOS after reboot.
I have to power off and power on again to bring it back and boot up.
Any idea what happen?
49 REPLIES 49
java2 wrote:
i flashed the bios to the latest one and loaded default setting but no luck.
to mine the lastest is 800 something (not near it now, so I can't recall precisely).
using 960 pro ssd too? is there any special bios settings applied?
kkn wrote:
i have the same board, and i do not have that problem.
i got the 950 pro
which cpu are you using?
kkn wrote:
i got the 950 pro
6800k
kkn wrote:
6800k
28 lane cpu there.
so its symptomatic.
the board just "****s" on them.
Malahmen wrote:
28 lane cpu there.
so its symptomatic.
well i have no problem whit mine, and i have w10 on it.
So you have 6800k (28 lane) processor running a m.2 drive on a rampage v extreme motherboard?
Is that it?
If so, can you tell us the version of your bios and how you've configured it so it can detect the m.2 drive to finish up installing the SO on it?
Because the drive is detected with a bootable pen, even starts to install, it just disappears on the next boot after copying the so installation files..
Is that it?
i got the strix board ( look at post number 2 as i said i had the same as he does ( exept i forgot to mention i got the 950 m.2 ) )
Ok, its a different setup.
I'm stuck with my options just the same.
Nevertheless the ssd version shouldn't be the problem.
Shouldn't, doesn't mean it isn't.
There is always that chance.
I just need to know if anyone managed to put one to work with a rampage v extreme (even if with a different processor).
Not going to bust a bunch of cash on a processor then get the same result. 😐
