x99 build advice
megan
hello ive just been building a very nice x99 system and and didnt know which power supply i needed normaly i just put a 1000 watt psu and thought that will do but this time ive decided to use a psu i would only need
my system specs are below thanks for your time in reading this
i7 5930k
asus rampage v extreme overclocked to 4.5
2x msi GTX 980 gaming 4g graphics cards
16gig of g-skill ripjaws 2666mhz memory
3x samsung evo 250gb ssd's
12x corsair sp120mm fans
3x corsair af140mm fans
1x D5 pump
4 REPLIES 4
aktivexkontrol
any 1000 to 1050 platinum from seasonic or enermax will do
http://www.seasonicusa.com/NEW_X-series_1050-1250.htm
http://enermax.com/home.php?fn=eng/product_a1_1_1&lv0=1&lv1=52&no=184
just asking why do you need 2x GPU?
how big is your screen and what resolution you want to run them?
megan
im using a 30" dell ultra sharp because with one gpu i was getting low fps in games so i bought another
Chino
Level 15
Hello Megan,
Welcome to the ROG forums. I'm sure you'll enjoy your new X99 system. The Rampage V Extreme is a very nice motherboard to overclock with and the gamer oriented features are top notch.
There is an offer on Newegg right now for the SeaSonic Platinum 1200W. You can get it for $204.99 after a $25.00 rebate. It's a pretty nice unit and will give you headroom to upgrade your components in the future.
megan
yeah the x99 system is a very nice system and thank you for the replys and i will go ahead and order one thank you for your time in reading this 🙂
