X870E EXtTREME with Ryzen 9900x3d Bios and Settings
rmm2018
Hey all!
Just got a new PC for work with x870e extreme and 9900x3d for work. I use it a bit for minor gaming, but main this is running FEA models and AI Models etc. Current bios is 1512
I was just wondering what optimisations if i should do (if any) to get the most out of the machine.
Silent_Scone
Super Moderator
Hi @rmm2018
Honestly, the best optimisation is using the right memory. What are you currently running?
Hey @Silent_Scone
I have 64gb  DDR5 CMH64GX5M2B5600Z40
You should see some uplift from switching to 6000 - 6400MT/s kits, in that case.
Taken from X870E Extreme QVL
Fire and forget, you can increase the boost clock by 200MHz, and reduce operating voltage.
  • AI Tweaker → Precision Boost Overdrive → set to Advanced
  • Precision Boost Overdrive Scalar → x200
  • Max CPU Boost Clock Override → +200 MHz
  • Curve Optimizer → Negative, All Cores, value 20
Test the system.
