x870e-e code 62 doom loop - seemingly random POST problem (v1504, v1512)
cjbturin
Specs:
Motherboard: ASUS ROG STRIX X870E-E GAMING WIFI
CPU: AMD RYZEN 9800X3D
GPU: GIGABYTE AORUS GeForce RTX 5090 MASTER ICE 32G (GV-N5090AORUSM ICE-32GD)
MEMORY: 4x G.SKILL F5-6000J3038F16G (4x16GB)
PSU: be quiet! Dark Power Pro 13 1300W
Background: system is not new, I've been using it since 2025-01 . In older versions of BIOS the only problem I encountered was long (up to 5min) memory training after changing bios settings, but BIOS v1504 fixed that. Recent changes - I upgraded the GPU to 5090 and upgraded the bios to v1504 about a week ago. Everything worked correctly until today. Now I'm dealing with seemingly random POST blocks.
Problem:
After booting, MOBO hangs usually on code 62, sometimes 70,68,97.
Performed 69 reboots in total, system booted successfully only 7 times, so right now I'm standing ~10% chance to boot successfully
Soft reboot (resetting through OS) after a successful reboot always boots successfully
After shutdown trying to reboot again yields random result – hangs or works.
Connected devices or installed memory sticks do not affect the behaviour – running it without any PCIE devices and only one memory stick does not fix the problem - behaviour is exactly the same.
Updating bios from v1504 to latest v1512 did not fix the problem
Doing a CMOS reset has no effect on the problem.
Once the system boots, it’s super-stable, everything works correctly.
I kept a full log of every action during debugging, here it is:
reboot no; POST code; note; successful boot (YES or NO);
1 62 NO
2 62 NO
3 62 NO
4 70 NO
5 62 reset cmos NO
6 62 NO
7 62 NO
8 70 NO
9 62 NO
10 -- YES
11 62 NO
12 70 reset cmos NO
13 62 NO
14 62 removed all peripherials (USB, PCIE – GPU,SSD), left only one 16G memory stick NO
15 62 NO
16 62 NO
17 62 NO
18 62 used bios flashback to update from v1504 to v1512 NO
19 62 NO
20 70 NO
21 62 NO
22 -- YES!
23 62 reinstalled SSD NO
24 62 NO
25 70 NO
26 62 NO
27 62 NO
28 62 NO
29 94 reset cmos NO
30 62 NO
31 94 Re-seated CPU NO
32 97 NO
33 97 reset cmos NO
34 62 NO
35 62 NO
36 -- YES
37 -- software reboot YES
38 62 after shutdown, 62 again NO
39 62 NO
40 62 reinstalled SSDS, all memory sticks NO
41 68 NO
42 -- YES
43 62 NO
44 62 NO
45 62 NO
46 62 NO
47 62 NO
48 62 NO
49 62 NO
50 62 NO
51 62 reset cmos NO
52 62 NO
53 94 NO
54 62 NO
55 62 NO
56 62 NO
57 62 NO
58 62 NO
59 -- YES
60 62 NO
61 62 NO
62 62 reinstalled GPU NO
63 62 NO
64 62 NO
65 62 NO
66 62 NO
67 62 NO
68 62 NO
69 -- YES
0 REPLIES 0
