Will the ASUS ROG STRIX LC II ARGB White Edition 360mm AIO fit in my case?
Bibbit
I have a Lian Li 011D MINI-W case and I'd like to get the ROG Strix LC II ARGB White Edition 360mm AIO for my cooling. I'm not sure if it will fit. I'm thinking it won't fit. What can I do to make sure it will fit before I buy the AIO?   Thanks!
X670-P PRIME WIFI | ASUS GTX 370 | AMD Ryzen 9 7900X | 64 GB G.Skill | Flare X5 Series | Samsung 940 Pro NVMe 1 TB | Samsung 950 NVMe 2 TB
4 REPLIES 4
Rooke
According to the link you provided, the case will accept a 360mm radiator in the top and bottom of the case.
See the attached image.
Have a Good One! 😎
Rooke
Thanks. I did look at that info, and it does seem as though it should fit, but I'm told by somebody else that my motherboard will be a problem. Apparently, the memory may get in the way. Low profile fans may be needed for it to fit.
MasterC
Community Admin
Community Admin
From what I can see on that product page, there's a fair amount of clearance. Their own AIO fits (69 mm) just fine, and it's taller than ours (45 mm).
That chassis also has a modular back panel so you can adjust the height of the motherboard (provided you are using a smaller form factor). Do you plan to put in the X670-P PRIME WIFI?
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
herringbur
I looked at the information, and it appears to fit, but I've been advised that my motherboard will be a problem.
https://rog-forum.asus.com/t5/hardware-build-advice/will-the-asus-rog-strix-lc-ii-argb-white-edition... geometry dash
