Your 860w psu might run it but then again maybe not. With that kind of water cooling I know you're going to be overclocking too and you will more than likely run into stability issues when overclocking.
One gtx 780ti and no overclocking requires a 600w psu, this is for total system power draw. You have 2 of them which right there is going to need another approx. 200 watts. Add in your cpu at 140 watts and you're already needing a 940 watt psu and that's not counting everything else. if I were you I would be looking at a quality 1200w psu to run what you have comfortably along with overclocking.
The more headroom you give your psu , the cooler and quieter it will run and the longer it will last.
