Wierd Profile Reset when using Volume-Wheel (Asus ROG Strix Flare)
SpiritLetsPlays
so since I installed the newest Update of Armoury Crate, I have a wierd bug. Every Time i use one of the Shortcuts at the Top (Play/Pause, skip etc.) or use the Volume Wheel, the Keyboard desyncs from Aura Sync. I get a Message if i try to sync it that the Keyboard can't be synced in Default Profile. I know where this Profile is, i changed to Profile 1, but every Time I press one of the Shortcuts at the Top or the Volume Wheel it just resets. Can anyone help me?
4 REPLIES 4
AjaxBU
I'm having the same issue
Hi! They said that new firmware will come this week.
Every gamer has suffered from small-screen videos
Thanks, ASUS support emailed me with “troubleshooting� steps that just uninstall armoury crate
I'm exactly having same issue with the Flare. Volume and other special keys cause profile change.
