06-27-2013 12:50 PM - last edited on 03-06-2024 08:45 PM by ROGBot
06-27-2013 01:54 PM
06-27-2013 02:12 PM
proudpiper wrote:
The Rampage IV Extreme doesn't have the mPCI-E combo card that the Maximus V series has. In fact, it also lacks a standard mPCI-E slot. Therefore, your options are either to buy a PCI-E wi-fi card or to use a USB wi-fi adapter. Personally I would recommend a high quality USB wi-fi adapter so you don't have to use up a PCI-E slot.
06-27-2013 02:37 PM
06-27-2013 02:54 PM
