Which SLI bridge 2 way or 3 way
mik666
Hello
Planning to buy 1 more 1080 strix.
I will also order an ROG sli bridge.
I have an R5E board.
I almost bought the 2 way because 2 way 😛 But i think i need the 3 way bridge Because i will use the 1st and the 3rd slot. Right ?
Thanks..
6 REPLIES 6
Arne_Saknussemm
Level 40
mik666
Ok thanks. thought so but just to be sure.
mik666
Now i read Asus is bringing a new bridge. This one is HB.
To be honest i like the enthusiast 3 way version more.
But will there be any performance difference between the two?
Thanks
Thanks
Yes, the HB version will benefit 10 series owners:
http://www.evga.com/products/product.aspx?pn=100-2W-0026-LR
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
Menthol
Level 14
If you have Pascal cards you need HB bridge, all HB bridges are 2 way only but with different spacing so make sure to research and order the correct bridge for the spacing of your cards
62107
Some LED type bridges such as EVGA/MSI also work fine as they have electrical contacts on both sides of the port on the bridge, I don't have an ASUS LED bridge so I cannot verify if they work or not.
Also you can purchase a 3D printed cover for a standard ASUS HB bridge https://rog.asus.com/forum/showthread.php?85505-Make-it-your-own-The-ASUS-3D-Printing-Project
mik666
Thanks guys,
I bought the one from Zotac.
Nice, clean design. A bit of mat black paint and a ROG sticker to match it my system.
