Hi
I am trying to build a quad GPU setup primarily for assisting in houdini simulations (some of their solvers has OpenCL options) and redshift and octane renderings.
which RTX 2070 (as they have the best bang for the buck) Model would be most suitable in a fractal design R6 Case for a quad GPU setup on a ASrock taichi x399 with a 2950X TR and 32 GB of RAM (if you have better suggestion for the motherboard please do let me know).
i would appreciate a lot if some of the testers and experts could shed some light on this
thanks
Manodzit
