02-02-201609:20 AM - last edited on 03-06-202402:51 AM by ROGBot
I'm wanting to try 4k gaming and can't figure out which 4k Monitor to get. I'm going to get 2 Asus Matrix 980Ti's. Any Insight would be appreciated. Thanks in advance
You Should get a 4K Monitor for 4K Gaming--- Nah But seriously, look for BenQ and Sony 4K monitors, they are absolutely sweet, though a bit pricey! Try for one or two 4K's as you can support 3 Monitors (With nearly no problems) With your setup 😛
I like the Benq 32", IPS, 4ms, 60Hz. There is also a phillips 40" 4k monitor but the bigger you go you lose pixel density and the picture isn't as crisp.
