Which 34" curved monitor?
CapnBAMBAM
So I am doing a complete overhaul on my pc this coming month. For the monitor I was debating between the Samsung 34" curved and the Asus 34" curved. Now I know this is an Asus forum and all but am wondering which would you all get? I have the original swift and have problems with it and am reading that the new one has quality issues, as does the acer 34" which is supposedly using the same panel as the asus one. I really only want asus for the oc'ing and gsync abilities, plus itll match my build but am a fan of Samsung when it comes to tvs and monitors (have 2 samsung tvs and had 2 of the Samsung 950d's when they were new and loved them. Which would you all suggest?
4 REPLIES 4
kkn
Level 14
Heini
Level 11
CapnBAMBAM wrote:
I have the original swift and have problems with it and am reading that the new one has quality issues, as does the acer 34" which is supposedly using the same panel as the asus one. Which would you all suggest?
I think you answered you're own question.
Vlada011
34" Curved Monitor is big investment and it's very bad if for few months show up nicer model.
ROG 34" Curved worth waiting few months.
InfernoStorm
Be prepared to be very disappointed, I personally would not invest in any 34" right now. Too many issues with bleeding for the higher refresh rate panels and since these are curved panels, the blacklight bleeding will be even worse.
