What UPS should I get for my Monster?
FrodBonzi
Hey all,
Finally got my PC back up and running - RMAd a broken Titan and all 3 are working (had a scare when one of my waterblocks got clogged and a Titan went up to 95C in like 15 seconds - all good now!)
Here's my new question: What UPS would you recommend for this setup?
Motherboard:
Rampage V Extreme
Processor:
i7 5960x
Memory (part number):
Crucial 64GB Ballistic Sport DDR4 24GHZ
Graphics Card #1:
nVidia Titan X
Graphics Card #2:
nVidia Titan X
Graphics Card #3:
nVidia Titan X
Sound Card:
On Board
Monitor:
Dell u2713HM (4k coming soon!)
Storage #1:
Intel 750 PCIE SSD 400GB
Storage #2:
Samsung EVO 850 Pro
Storage #3:
Seagate 6TB
CPU Cooler:
EKWB - Radiator, pump, waterblock (CPU and Video Cards)
Case:
Corsair Obsidian 900D
Power Supply:
EVGA 1600W
OS: Win 10 Pro
kkn
Level 14
only way you would need a UPS ( in my honest opinion ) is if you live in a area whit short outs.
or in a home whit unstable power fluctuations mabye.
but if you think you need one by all means, get one just to be on the safe side.
i dont have one so this was my opinion.
Ntwlf
Level 12
Hi FrodBonzi,
With the crazy weather these days around the world, you never now when the power is going to be interrupted. So I feal a good UPS is a must. I've been using this one for the past 4 years with no problems. http://www.newegg.com/Product/Product.aspx?Item=N82E16842101419 I've replaced the internal gel-cell batteries twice during this time to maintain top reliability from the UPS.
Here's APC's website with a calculator to help in choosing a UPS for your needs. https://www.apc.com/products/family/index.cfm?id=27&tab=models
A Watt Meter like these http://www.newegg.com/Product/ProductList.aspx?Description=kill-a-watt&Submit=ENE will help in knowing the wattage draw of your system.
In using the watt meter, plug it into the wall and connect your PC, Monitor, Modem, Router, etc. into a power strip and then connect the power strip to the Watt Meter. The Watt Meter will tell you what the combined devices are drawing at the plug that you need covered by the UPS. The UPS I suggested should be more than enough for your needs.
I hope this helps you in making a decision.
