09-24-2020
02:58 PM
- last edited on
03-05-2024
07:11 PM
by
ROGBot
10-21-2020 07:45 AM
11-19-2020 10:53 AM
Nicklas0912 wrote:
Hello.
I got a lucky ordre on a RTX 3090 Strix, But I can see there is also a version that is called RTX 3090 Strix OC.
what is the difference?
THE PCB, anything should be the same, as I can see the only difference is that the Strix OC just come with a higher OC out of the box, and that is the only thing? you can even put the Strix OC bios on the Strix card I guss? as it is the same card?
Asus RTX 3090 Strix: https://www.asus.com/Graphics-Cards/ROG-STRIX-RTX3090-24G-GAMING/
Asus RTX 3090 Strix OC : https://www.asus.com/Graphics-Cards/ROG-STRIX-RTX3090-24G-GAMING/
Hope some one reply, thanks 🙂
01-09-2021 04:13 AM
01-15-2021 05:48 AM
01-15-2021 06:45 AM
