What do u think?
IcedBerry
Hi together,
i want to order a new PC.
What do you think about my Config?
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/1919ce220b445a3f23d...
Case: Zalman Z11 Plus
CPU: Intel Xeon E3-1231v3
CPU-Heat-Sink: Thermalright HR-02 Rec.A (BW)
Mainboard: ASUS Maximus VII HERO
RAM: 16GB (4x4GB) G.Skill RipJaws
Graphic: 2x ASUS ROG GTX760 Striker Platinum
SSD: 1x 240GB Curcial M500 SSD
HDD: 1x 1TB WD Black 3,5"
Fan Control: NZXT Sentry LX
PSU: Corsair 760AX
9 REPLIES 9
jab383
Does a z97 support a Xeon? I thought Xeon needed C220 family chipset.
Jeff
IcedBerry
I dont think so. It´s the same Socket and pcgameshardware tested it with an 1230v3 🙂
Whats about the parts?
PSU: Corsair 760AX
kkn
Level 14
dont forget memory
abvolt
Level 11
that list looks great.
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
kkn
Level 14
you forgot to add memory to that list of yours ( like i posted abow ).
No 1 Kit 🙂
PSU: Corsair 760AX
IcedBerry
I got 16GB @ Home ^^ so i dont need to buy ^^
PSU: Corsair 760AX
kkn
Level 14
ah ok, as long its 1 kit and not a mix of 2 or more.
I´ll make make an unboxing / testing / benchmarking video when the Hardware arrives 🙂
PSU: Corsair 760AX
