11-15-2017 04:03 PM - last edited on 03-05-2024 09:45 PM by ROGBot
11-15-2017 04:21 PM
11-15-2017 08:11 PM
11-16-2017 02:29 PM
GEEKCPA wrote:
When you say "two straight pipes" do you mean one in to the intake port on top, but plugged on the bottom, and the top side of the outlet port plugged, with the bottom outlet pipe going straight in to the second card's outlet port with a plug on the bottom. The inlet port of card 2 is plugged on top with a pipe coming out the bottom and voing to the pump or radiator? The instructions that came with the blocks are confusing. They imply the intake port is the one closest to the front of the video card, but the directional arrows appear to be backwards. Am I getting something wrong?
11-16-2017 05:20 PM
Georgia wrote:
Like This, input is on the left side of the GPU's,output on the right.
11-15-2017 11:31 PM
11-16-2017 07:46 AM
11-16-2017 11:31 PM
11-17-2017 06:21 AM
