Using Rog 140w gan charger with flow z13 gz301vv 2023
renedan11
I really need some help with my flow z13 gz301vv 2023. I recently received mine from a relative thats already used but the original charger that came with my laptop is missing and now i am using a flow z13 acrnm RMT02 charger for it. I have noticed on nvidia relay performance that my gpu power draw is only averaging at around 35w and sometimes spikes from 35w to 40w to 42w for a split second when turbo mode or ultimate mode is turned on while gaming. The charger that im using isnt the original one that actually came with the laptop but the charger itself is authentic, just not the one that came with the laptop. The specs of the charger is identical to the original and i can also use turbo mode, just to clarify. However, when i play warzone it can barely maintain 60 fps on 1080p lowest settings with fidelityfxcas or dlss performance settingss. Meanwhile in pubg, 80 to 100 fps at 1080p high settings, low shadow. I already gave up on mux switch even switching to ultimate mode plus turbo mode it barely gives any improvement especially in warzone. It still shows me 35w average gpu draw on nvidia relay performance stats despite all of the things that i tried. I reinstalled gpu drivers, update my windows os, checked for bios updates, myasus updates, armory crate updates and still no improvement which made me come to a conclusion that the charger is the problem because im not using the original one that came with it. Now i wanna buy the rog 140w gan charger but im skeptical about it if it can give me the same full performance of the original charger that came with the laptop. Is it compatible? Will it give me identical full performance just like the original charger that comes with the laptop? Its expensive and i dont want to order one to just test it. Please im begging for honest answers and help from anyone. Thank you.
0 REPLIES 0
