07-19-2022 07:58 AM - last edited 3 weeks ago by ROGBot
07-19-2022 08:50 AM
ahfoo wrote:
I am sorry to inform you that you cannot connect 4 pins to connect to mob. You need a 8 pins from PSU to do so.
07-19-2022 09:45 AM
ahfoo wrote:
I am referring to to the mobo that you use for Intel 10100f. For my understanding that intel series mobo support 8 pins If my memories did not failed me.
07-20-2022 03:17 AM
sajad564 wrote:
tnx alot
so what you said means :
yes we can use 4 pin cable in 8 pin mobos(because people on internet said they did it before)
but thats not works for this motherboard and this motherboard need 8 pin ?
07-20-2022 06:12 AM
ahfoo wrote:
In short your mobo need 8 pins connector from your PSU to your mobo and 4 pins will never work.
07-20-2022 03:54 AM
07-20-2022 06:16 AM
DragDay7 wrote:
If 8 pin is enough to handle 190W CPU (12700), 4 pin should be enough to run 95W CPU, right? Actually 4 pins are rated to handle up to 105W. Yours require 65W and peaks up to 90W.
I say it should be fine.
07-20-2022 03:03 PM
sajad564 wrote:
in old motherboard yes that works fine
but about new motherboard there is different answers
some one say "yes" some one say "no"
I wonder why nothing is written about it in the manual file
