Use of the TUF F15 being closed with external monitor
littbarski
Hello everybody,
I would like to use the F15 laptop with an external monitor, and it would be the best solution to just put it on the desk before the external monitor, but always closed (laptop monitor closed on top on the laptop keyboard). It works fine, I also tried some games. But I saw some air slots at the right next to the on/off key. And I read some opinions about it. So my question is:
Can I use the F15 being closed when using a second monitor (monitor of the F15 is off then of course) also for gaming or do I have some temperature issues then which are not meant in that way for the laptop monitor LED or the other hardware components? So is there some laptop architecture by ASUS made in that way that I can use it closed for gaming or is this not at all recommended?
Thank you!
0 REPLIES 0
