usb device no recogized
Giannis996
hey guys i have a maximus vi extreme and i have a the following problem: it continiously spamming me that usb device not recognized and i continiusly hear the in /out usb sound i cant locate which usb has the problem i suppose is one out of the two usb 2 ports on the back i/o as i dont have plugged any other usb devicen onto the mobo i have install latest drivers for usb3 nd chipset drivers but i cantfind the solution any ideas???
Project Name: System Specs:
Motherboard: Asus Rampage IV Black Edition
Prossesor: Intel Core i7 4820k
Graphic Card: Asus GTX Titan x2
*Power Supply: Cooler Master V850
Ram: 32Gb Corsair Dominator Platinum 2133Mhz
Case: Corsair Obsidian 750D
SSD: 2x Samsung Evo 250Gb Raid 0
HDD: 2x Seagate Baraccuda 2TB
13 REPLIES 13
Giannis996
the problem is that there is no usb plugged....
HiVizMan
Level 40
How are you connecting your Keyboard and mouse?
24778
i hope this helps...
Giannis996
via usb but i get the message even without keyboard and mouse i get it with empty back i/o im only using the intergrated graphics hdmi port today i formated the pc and installed all the lates drivers..still the same problem...
Giannis996
24800
i also found this if it helps...
HiVizMan
Level 40
Do you get this same error if you have your mouse and keyboard in different ports.
Giannis996
yes! i also get it even without mouse and keyboard and even without ANY usb plugged i also found this i hope it helps even more
24832
im now sure that its The Universal Bus Controller's fault..but how i fix it first time countering this....
HiVizMan
Level 40
OK just for your information the USB controller is on your CPU and not your motherboard. Do you have the third party Asmedia USB drivers installed?
Giannis996
yes i do have this:
24833
