USB 3.2 Gen 1 Front Panel module
TheRock
Hi All,
I have been searching for quite some time today but not finding this item.
I am looking for a USB 3.2 Gen 1 Type-A module for the front panel connection. I seem to have found the Type-C but not the Type-A. I have the ASUS ROG Strix Z590 MB and wanted to change my USB 3.0 Type-A front panel case connector(s) to 3.2 Type-A. I would like to get the cable also that plugs into the 3.2 socket for the MB. I would even be happy if i could find a 5.25 or 3.5 drive bay front panel USB 3.2 Gen 1 Hub. Seems I can only find the USB 3.1 drive bay hubs. I have also found the PCIe 3.2 cards but I don't want to use the MB PCIe slot.
Can someone direct me to a place in Canada or USA that I can buy this item. I have searched Newegg and Amazon and can't find it.
Greatly appreciate any help
Just found out that the USB 3.2 Gen 1 is same speed as the 3.0 so now I know it is pointless to look for a new module.
cheers
0 REPLIES 0
