08-17-2017 07:36 PM - last edited 3 weeks ago by ROGBot
08-22-2017 05:32 AM
Omyth wrote:
So im thinking of getting this one.
https://www.amazon.com/FSP-Platinum-Certified-Modular-PT-1000FM/dp/B00NWE9RNW?tag=bom_tomshardware-2...
its a 1200W PS, the 100W one wich was the only one on that list from above was only 50$ cheaper. What do you think about this?
08-22-2017 06:15 AM
DevBiker wrote:
Based on reviews, it's an excellent PSU. However, 1200W is overkill for your build ... I'd save the $50 and get 1000W (or less). I wouldn't go lower than 850W unless you are replacing the GPUs. You don't gain anything by getting an overpowered PSU except a lighter wallet and, perhaps, bragging points.
08-21-2017 08:40 PM
08-21-2017 10:23 PM
08-25-2017 11:48 AM
08-25-2017 01:39 PM
Omyth wrote:Something to look into for your setup http://www.overclock.net/t/1426444/max-safe-voltage-for-4770k-24-7-under-water
Update, so for so good. I drained and cleaned out my system, replaced the PSU with a 1000W one. I am about to run some stress tests to see if it shuts down on itself again now. Did the GPU tests already and nothing went wrong. Altho I am unable to OC to a stable amount, I am stuck using the optimized defaults in bios. There is 8 preset OC profiles already in place but none of them are stable and wont alow the pc to stay running for more then 10min lol.
08-25-2017 03:26 PM
08-25-2017 09:12 PM
Omyth wrote:Awesome [emoji1]
So after 3hours 30min of Prime85 testing, I think the system is good. Using 100% of the cpu the entire time the temps reached a high of 61C. Thanks for everyones insights and help! saved me a lot of money lol.
