Udgrading Max V Formula from Win7 64 Ultimate to Win 10 ?
Leatherskull
Hi Folks -
Are you members running Win 10 Pro on your Maximus V Formula mother boards??
Concerning my Maximus V Formula mb:
When attempting to upgrade my "Intel 82579V Gigabit Network Connection" (Version 12.2.45.0 dated 8/10/2012) in Device Manager, - to the latest version (PROWin64.exe V 22.1 dated 3/27/2017) reported by Intel Driver Update Utility (V2.7.2.4) the following occurs:
When clicked to install the new Proset driver it proceeds but then an error message pops up. "The installed version of Intel Network Connections is not supported for upgrades. You must uninstall it before installing this version." But then an Intel window ppops up requesting a reboot to finish. After a reboot, Device Manager still lists the driver as being the old version, but a rescan by Intel Driver Update indicates the new version 22.1 is installed?
I have no idea how to proceed with correcting this as I do not see a specific listing for the driver in Prograsms & Features for "uninstall"
I want to upgrade from Win7 64 Ultimate to Win10 Pro and I understand that the 22.1 version of the 82579V is required for it to work on my Maximus V Formula.
I would greatly appreciate any help and/or advice towards facillitating this deiver update. Thanks
RIG to date:
* Thermaltake Level 10 GT case * Cool Power Gamer 980 watts * Maximus V Formula mb *
* Intel i7 3770k cpu * Corsair H100i cooler * Corsair Vengeance 16GB [2x8] 1600 ram *
* Sapphire R9 270X Toxic 2GB gpu * OS Win7 64 Ultimate *
* Corsair VOID 7.1 Wireless Headset *
* Monitor - LG 42LK520 LCD TV * SSD [OS] OCZ Vertex 4 256GB *
* Data HDs: SG 3TB, SG 3TB, WD 500GB *
* Webcam Logitech C920 * BluRay Burners: ASUS BW-12B1ST and LG WH12LS39 *
* ASUS ROG Maximus X Formula mb
* Intel i7-8700K cpu @ 5.0MHz
* Corsair H100i cooler w/ ML120 fans
* Corsair Vengeance RGB 32GB (4x8GB) DDR4 3333MHz C16
* OS Win 10 Pro 1903 64bit *
* ASUS ROG-STRIX-GTX 1080TI-011G
* Onkyo TX NR656 AV Receiver - 7.1 Spkrs
* Corsair VOID RGB Wireless Gaming Headset
* Corsair Scimitar PRO RGB Gaming Mouse
* Dual T.16000M FCS
* SSD [Star Citizen] Samsung SSD 860 EVO 250GB
Menthol
Level 14
I recently installed Win 10 on a MV Gene, clean install not upgrade, I don't remember needing to install an NIC driver or sound driver, the drivers in Windows worked just fine.
If your upgrading you may want to uninstall all drivers before updating and let Windows install new ones , or perform a clean install
If you refer to the ASUS downloads for this board there is no NIC driver for Windows 10 and other drivers are beta
https://www.asus.com/us/Motherboards/MAXIMUS_V_FORMULA/HelpDesk_Download/
