TUF GAMING Z490-PLUS XMP POST safe mode
Daniel_Shaw
Hi there
When i enable XMP on my settings, 3200mhz ram the bios wont post and goes into safe mode,
I have tried it manually set to 3200mhz with voltages etc still no avail.
Please advise, Kit I have is the CMT32GX4M2C3200C16
Thanks
MoKiChU
Level 40
Have you placed your RAMs correctly on slots A2 and B2 and not A1 and B1 ?
Did you try the XMP 2 mode (the XMP 2 respect default XMP timings, while the XMP 1 optimise XMP timings) ?
MoKiChU wrote:
Hi Sir
You are a genius, I had the ram in A1 B1 moved them over a notch each and XMP 2 working a treat now 🙂
Thank you
