TUF 1200 Gold PSU - Fan not spinning on start
animalmom
Got this new PSU recently to replace one that wasn't working.  Worked fine for a week, now I am getting code 00 on startup - fan is not spinning on the PSU which I understand may be normal.
The Mobo is getting power (I can see the 00 code) and various RGB are working so it is not dead but I am curious as to whether the PSU may be having an issue since the fan isnt spinning.
1 ACCEPTED SOLUTION
Accepted Solutions
achugh
Level 14
Hi @animalmom I am sorry to hear about your troubles. Code 00 on your board is an indication that your PSU has developed a fault and is not functioning properly. This is also visible to you since the PSU fan has stopped working. You will need to take it to a repair shop, or get it RMA if it is under warranty or buy a new one.
Disclaimer: I am not an ASUS support person so my information may be incomplete. Always follow official documentation and material provided by ASUS representatives.
INTEL i9-14900K / CORSAIR VENGEANCE RGB 192GB (4x48GB) 5200 CAS38 / ROG Z790 DARK HERO / ROG TUF GAMING RTX 4090 OC / ProArt PA-602 Case / SEASONIC PRIME TX-1300 ATX 3.0 / CORSAIR MP700 PRO 2TB PCIe Gen5 / CRUCIAL T500 2TB PCIe Gen4 / EIZO CG2700X
achugh
Level 14
