Hello there.
I have a super simple question which I can't find its answer anywhere.
I own a H370-F mobo and its I/O shroud's LEDs never gave a sign of life since day 0. Since I needed the PC for work and reasoning it never impacted on its performance, I couldn't really care to spend a lot of time on such pretties. Now I have some time and I'm even investing a little bit on the look of my build, so it's starting to mock me.
I've noticed, on H370-F manual, that there is a LED1_CON1 connector under the bridge of my mobo.
Manual image:
https://i.imgur.com/RaiXjss.png... I builded the PC myself and couldn't really understand what it was for at first sight. I understood it was a hidden (?) connector for a LED strip or something. Basically, purely optional, but Aura software never ever started on my PC since I've been trying and I think it has to do with it.
Which brings me to the
TL;DR questions:
1- Is the LED1_CON1 for the LEDs on the I/O shroud?
(refer to the manual image link above to understand)2- If positive, how can I connect a LED strip later since the H370-F only has one RGB header?
Thanks in advance.
