Trying to decide on RAM speed for Intel 9900K
Sverre
Intel 9900K
Maximus XI
Poseidon GTX 1080ti (until I can afford RTX 2080ti, but uncertain if it's worth it)
Water cooled with 1 loop for the CPU and Mosfets and 1 loop for the GPU's.
I've searched a bit for some benchmarks with 9900K vs different RAM speeds, but can't find anything. I know 3200Mhz is the best for 8700K (any higher gives little extra), but I would guess the 9900K can benefit from something with a higher frequency? Has anyone done any benchmarks for this combo?
[/URL]
ninezerofive
For 9700K i've got myself 4000 CL17 kit. That would be my advise for the high end ram. That's the last of the rams that can run at 1.35v. Anything higher than that and you will get much higher latency and higher voltage kits. Here's the video bro, decide yourself.
Sverre
Thanks! Guess I'll be checking prices for 3400-3600 for a few weeks. 🙂
[/URL]
