Touchpad not working properly
assuc
HI,
I have recently upgraded to windows 10 pro edition to Home. I installed a fresh copy on GL502vt ROG Laptop.
Touchpad doesnt seem to work properly.
I have installed the driver and smart gestures downloaded from asus website.
Touchpad jitters and pointer runsaway from one place to another. Single left click sometime causes right click.
Kindly help me what is wrong with the touchpad, how can i solve this problem?
72247
BigJob
Reinstall drivers.
Check Control Panel > Mouse settings
Disbale touch pad, attach usb mouse and see if same problems persist.
I TRIED TO DISABLE TOUCHPAD. USB MOUSE IS WORKING FINE AND i AM USING USB MOUSE SINCE THE TOUCHPAD IS NOT PROPERLY FUNCTIONING
Anyone with any clue what is the problem. half left of touchpad works fine while the right half doesnt work well.
