thermal pads
blukas69
can they be stacked for instance 1mm + .5 mm to give 1.5mm.
or is that a bad idea.
Thanks
DjRavix
Thanks
it does work but it is not recommend
Use 1.5 mm thick thermal pads if you need 1.5 mm tick thermal pads
ASUS Maximus 13 Extreme
Intel i9 11900K
Corsair Dominater Platinum RGB
Phanteks Enthoo Primo
Samsung 980 Pro 1TB
2 X Samsung 980 Pro 2TB
Corsair AX1200I
EK-Velocity D-RGB - Nickel + Plexi
EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
XSPC RX480 + XSPC RS280
4 X Corsair SP120 PWM OEM Fans
2 X Noctua NF-A14 industrialPPC-2000 IP67 PWM
2 X Noctua NF-A14 PWM chromax.black.swap
2 X Noctua NF-S12A PWM chromax.black.swap
1 X Noctua NF-A15 HS-PWM chromax.black.swap
blukas69
Thanks
ok thats what I thought Thanks for quick response
