08-15-2019
08:18 AM
- last edited on
03-05-2024
07:32 PM
by
ROGBot
09-19-2019 04:21 AM
09-19-2019 08:38 PM
12-14-2019 08:06 PM
Aly1984 wrote:
I am in the same boat as all of you. Weird behavior on Temp 2 and 5 , when the air con is on, room temp at 22-23C these readings increase and plateau at about 85C and 87C. When the room temp increase say 27C to 30C these drop to 69C and 75C. Also on a Intel Burn test, Temp 5 disappeared Once.
All settings at default in bios (1201) . PBO is at auto. No significant effect on these sensors when core voltage is dropped to 1.25V to 1.35V. System is stable have not encountered any shutdowns or resets on any benchmarks.
Ryzen 3900X , 32 GB 3200MHz , 2070 super, Corsair RM850X.
03-22-2020 11:43 PM
03-31-2020 09:33 PM
06-25-2020 01:22 PM
06-26-2020 05:06 AM
11-16-2020 12:55 AM
alphamachine wrote:
Okay, something f*cky is going on. I cranked my A/C down to the lowest it would go and let it run for a while, then I took a box fan and pointed it directly into the side of my PC, and every temp in the system dropped into the 20's Celsius, except Temp 2 and Temp 5. Those WENT UP, and rose into the 90's Celsius. It makes NO sense to me. The longer I held the fan onto the motherboard, the higher those two temps went. I've never seen anything like it in the 20 years I've been building and maintaining PC's.
In the screenshot, look at the lowest temps of the rest of the numbers and the highest temps of Temp 2 and Temp 5. I just couldn't hold a box fan and take a screenshot at the same time. This has got to be dangerous. I mean, the components, whatever they are, are cooking, reaching over 200F. It's insane. No component in a PC should safely run at idle at 80C+ all of the time, much less jump into the 90's when better cooled. I'm just at a loss. It can't be boost, because I've disabled that. Nothing should be changing, and it shouldn't have been boosting anyway, because it was at an idle state at the desktop.
