Hello,
I would like to ask for some technical advice related to a recent issue with my PC. I have been using this rig for over 3 and a half years and I have not had issues up to this week.
This week when I powered up my PC, I hear it start, the fans start to work, but before the ROG logo appears, I hear a "click" and the system resets automatically. After the reset it takes me to a screen where I need to enter the BIOS settings. When I enter the BIOS I see that the AI Overclock Tuner is set to AUTO and memory clock frequency, voltage and timings are set to the default values. After that I can make any changes (set the memory clock and voltage higher), start the system and it will load Windows as expected (after ROG logo and boot).
Due to this, I supposed that there was some problem with the memory and tried to set the memory to 2133 MHz instead of 2400 MHz with a lower voltage. I also tried to leave it on the default setting (1333 MHz) but still the system resets on power up. (The second time it starts without any issue, and there are no shutdowns during runtime.)
I am looking for some advice on how to find the cause of this problem as it is probably not a memory issue.
I have changed to Windows 10 from Windows 7 2-3 months ago, I am not sure if that can be related.
Temperatures seem normal, there is no overheating:
CPU temperature beteen 32-35°C and Motherboard is also in this range, cooling seems to function normally.
One interesting addition, that when I installed Windows 10 some months ago, I ran the 4-Way Optimization function of Asus AI Suite, which configured the CPU, fans and maybe other settings too(?). After that I have been facing a similar issue: there were random shut downs (with blue screen) while Windows was running, and I could solve it by lowering CPU voltage in BIOS. It seems that the AI Suite has overclocked the CPU too much.
Please share any thoughts on how to solve this issue :confused:
Thank you for your help.
