Strix x570-e + best RGB corsair memory
mitcon
I'm thinking about getting a Strix x570-e MB and I want 32GB RGB memory that wont give me problems. I'd prefer Corsair RGB because of iCue compatibility with Asus MB. What is the most stable DDR4 32GB for this board, it would be awesome if it could do 3733 speed (think read is sweet spot) I'm thinking of ryzen 3700x cpu.
What are other strix x570-e owners using or suggest please?
rsweeko
Hi. My Crosshair viii hero x570 manual states everything over 2666 mhz is OC'ing. I use the qvl listed G.Skill Trident Z Neo (F43600C16Q-32GTZNC). On boot my BIOS registers it at 2133 Mhz and it runs OK. I did have a problem setting 3600 Mhz in the BIOS. The system hung up with a F9 Qcode. I have been working with The ASUS group with this. Good people. My PC is running great now on 2133 and I do intend to bump it up to something stable. Actually before I reset the CMOS, for another reason, the BIOS set the DDR4 at 2133, I then set the memory at 3600 and the BIOS changed it to 3573 Mhz and the PC was running great.
Not supposed to but I guess every mobo can behave differently. Good luck.
