Strix X299-XE Gaming and Cosair AIO question
fubat
Hi all,
I am not really sure if I should be connecting my Corsair H 150i Pro to my Mobo CPU fan header or my AIO Pump header. I have been advised by Overclockers UK to connect to the CPU header, however even on the lowest O/C (using EZ Tune Wizard), things are unstable. I was wondering if connecting to the AIO header would lead to better results, and cooling.
Thoughts and suggestions please guys:
Specs
ASUS ROG Swift X299 - XE Gaming
Intel i9-9900X @3.50GHz
64 GB Team Group DDR4 3600MHz ram
Corsair H 150i Pro AIO
Arne_Saknussemm
Level 40
Connect the pump header to AIO header...
Connect fans to CPU header...or set CPU header to ignore monitoring if you are powering fans by some other means
