01-03-2025 01:01 AM
Hey guys,
I've recently encountered an issue where a single red LED starts flashing on the far left power connector and only occurs when the GPU is in heavy load mode.
Any insights or suggestions would be greatly appreciated!
01-03-2025 01:32 AM - edited 01-03-2025 01:33 AM
The flashing could indicate a voltage issue if under load.
1. The 12v voltage is lower than 10.8v (Power Detection).
2. Among the 12+4pin power supply, one of the pins or pin contact is abnormal
2a. A single pin exceeds the set current value.
2b. There is no pin contact.
