Strix 690A mobo with 2 3090 cards water cooled neede to know size of space on slot1
Ultrasonix
i want to buy a Strix 690 A Mobo i have 2 RTX 3090 FE cards with EKWB water blocks and EKWB water back plates these add 16mm to the back will this card fit into the PCI 1 Slot on the motherboard as there are no dimensions shown in the manual for above the Slot but it does have a M2 card installed who's width is 22mm or so
can i assume my water cooled 3090 will fit and is the bottom slot 3 or 4 slots away as i have SLI enabled 3090s and link currently installed is for 4 slots
any please help
thanks
0 REPLIES 0
