10-16-201805:01 AM - last edited on 03-06-202409:58 PM by ROGBot
I bought a rgb strip to use with my z370e rog strix and I can not connect it, in the bundle of the motherboard there is cable but the pins are too large to be inserted into the lights connector, I also tried a direct connection to motherboard but don't work because "ground" pin remains uncovered, the strip is ws2812b and in the manual it says it is supported, what should I do?
