Stock OC Builder: Flow Custom Designed Gaming PC.
Jnanislore
These are my system's stats: If you need more info about the build and its design, refer to previous posts and discussions regarding my build on the forums, which I've already posted. This is a proven build and has been thoroughly tested and is satisfactory.
wakefulgybe
Look at this system to take the correct tunnel rush
