Spacing advice on CPU coolers
xAOCx_Death
i have a Fx 8120 thats running a bit hot on the stock cooler. i want to upgrade the CPU cooler but i fear i will have spacing issues in my NZXT Phantom case with the side 200mm fan installed. any recommendations would be helpful.
4 REPLIES 4
Chino
Level 15
xAOCx_Death
NZXT Phantom Full Size Tower, AMD FX-8120, 16Gb GSkills Sniper, XFX Radeon HD 6870 1Gb., NZXT Hale90 750watt,
Vortex 4 128Gb, Seagate barracuda 1Tb, Windows 7. any thing else you wanna know?
xAOCx_Death
Preferrably under a $100.
Chino
Level 15
If you feel comfortable about water cooling you can get the Corsair H80i for $99.99. Offers great cooling and you won't have to worry about the side fan nor RAM clearance.
